I'm interested in getting the Pioneer SC-1222K or Yamaha RX-A820 from Newegg, but I'm not sure on the speakers I should get. My budget is $600 for speakers. The Pioneer SC-1222K is currently $530 and the Yamaha RX-A820 is $900 and on weekends you get $370 gift card from Newegg, which I plan on using for speakers. I am leaning toward the Yamaha as a way of future proofing with its 4K up-conversion. Any suggestions on surround sound package or what speakers I need to build a surround sound system.Presently I have a Technics SAAX6, which I got when it first came out, like 12 years ago. I want to replace it as some of the terminals no longer work. I have 2 JBL satellites rated at 125W and Pioneer center at 160W I believe. If these speakers would be fine, I'll keep them and just add Sub and 2 front and 2 rear.
These are some of the speakers I liked, let me know which if any would be a good fit with either receiver:
http://www.bhphotovideo.com/c/product/631442-REG/JBL_CONTROL_ONE_Control_One_Monitor_Bookshelf.html
http://www.bhphotovideo.com/c/product/543184-REG/JBL_ES10BK_ES10B_3_Way_Bookshelf_Speaker.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290269
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780012
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325104
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269024
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290215
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325105
The wife won't be happy about that lol.
