AVS › AVS Forum › Video Components › Home Theater Computers › Need Help with Set Up
post #1 of 6
Hello,
I used Assassin's blog (which is excellent) to set up WMC and Media Browser. I installed LAV Splitter, and ran as Administrator. I installed both 32 and 64 bit components, and set things up exactly as the guide says.
I also ran Graph Studio 64 bit, and no matter what MKV file I render I NEVER see LAV Audio Decoder handling the audio. It's always Microsoft DTV-DVD Video Decoder shown handling both video and audio.
What am I doing wrong? Should I disable Microsoft DTV/DVD Decoder? I did install WIN TV. Could THAT be the problem?
I have about 100 Blu Ray and DVD's ripped using MakeMKV, and they ALL play and sound fine using VLC, but I have audio problems on most when using WMC and Media Browser...
Thanks in advance,
David
Edited by dpn - 3/2/13 at 3:55pm
post #2 of 6
How and what are you connected to?
post #3 of 6
Assassin,
My HTPC is an I3 -3225 CPU, Z77 Gigabyte MB, 180 GB SSD, 8 GB Ram, etc. connected via HDMI to an Onkyo TX-SR608 and feeding a Mitsubishi 1080P projector and a Phillips 50" LCS HDTV. I am about to change to a Onkyo HT-RC460 next week.
Should Graph Studio show LAV Audio Decoder even if I'm just connected to a PC Monitor?
David
Edited by dpn - 3/5/13 at 7:06pm
post #4 of 6
Help?
post #5 of 6
What is showing up as being connected? The Onkyo? Or one of your two displays?
post #6 of 6
I will have to check when I get home. I am at my office now.
I will respond later tonight.
Thanks for the help, Assassin!
Also, should I remove VLC? Could that be interfering with LAV?
David
