AVS › AVS Forum › Audio › Receivers, Amps, and Processors › volume control gets lower when receiver is turned off and back on fisher 2 channel receiver need advice
volume control gets lower when receiver is turned off and back on fisher 2 channel receiver need...
post #1 of 15
Do some receivers do this? I mean is it normal? i got it used a few months ago so I wasn't sure. None of my other receivers do it though. please someone help me figure out what this means. I will have it loud when it's on but when it turns back on much lower volume then where I started at.
post #2 of 15
It probably has a minimum volume setting. That is so that if you have it very loud when you turn it off it wont come back on and damage the speakers or make you crap yourself. smile.gif What kind of receiver do you have?
post #3 of 15
I like the tiger on your profile. it is rs 717 studio standard. Since it has been doing that right now I have pioneer speakers hooked up to vc rx 250 playing through the computer using shoutcast.com
post #4 of 15
Thanks about the tiger. Does the avr come on at the same volume each time?
post #5 of 15
yes it does so some receivers just do that then?
post #6 of 15
since you like tigers you should go to cincinatti zoo and see the famous cheetah run. I tried to go to it, but missed it by about two or three hours. the zoo was still fun though.
post #7 of 15
Yes. If you read the manual I bet you can set that volume to be whatever you want. It will be a minimum volume setting of some type.
post #8 of 15
ok thanks. I wish I had the manual lol. I got it from goodwill for 13 dollars.
post #9 of 15
You can probably find it on the internet.
post #10 of 15
I just made a quick search and couldnt find it except one for sale. Just go into the settings and see what you can find.
post #11 of 15
would you use jbl speakers and sansui with a rotel power amp or a heath pre amp and heath power amp. I have both brand speakers. I don't know which amps would sound better with the speakers.
post #12 of 15
I have no clue but most amps sound the same. Most of the experts here will tell you that an external amp will not improve sound quality in most cases. Use the best speakers.
post #13 of 15
just curious what amps do you use bond?
post #14 of 15
Only the one in my Yamaha RX-V671 surround receiver.
post #15 of 15
I have a older yamaha surround receiver also with a problem. it sounds fine on cd players, but the sound cuts out when hooked up to my hp all in one pc in the livingroom. I haven't used the yamaha in a few months. the nad ended up going in the livingroom instead. I wonder what is making the sound cut on when I hook the 3.5mm cable with the red and white cables on it. the nad has no problem playing sound through the headphone port. the yamaha will work fine with iphone hooked up to it using the 3.5mm plug but won't on the pc.
