AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Dubbing from disc to HDD
post #1 of 5
I know I must be doing something wrong but when I try to dub from a recorded disc to the HDD, when I go to Menu the dubbing doesnt light up, Can someone help me with this
post #2 of 5
Tested this on my 2160 and got the same result. I can't remember trying to dub a finalized disc to the hdd before, but you can dub an unfinalized disc to the hdd. So, if the disc you want was recorded on the Magnavox, you can undo the finalization, and the dubbing option will now show.
post #3 of 5
The help file on Dubbing Finalized and Unfinalized discs to HDD is here.
A list of other help files is here.
post #4 of 5
I want to thank all those who replied to this thread and especially Wajo because his tip worked. Others who have had the same problem I have would do well to follow the tip posted by Wajo. Thanks again the help was greatly appreciated
BK63
post #5 of 5
BK63
So, was it the MRC setting, or something else?
  Back to Forum: DVD Recorders (Standard Def)
