Originally Posted by
Wisoonsta
The only problem is that they have a red/black wire slot (Bi-wire?? - Not sure)
It has nothing to do with what's known in the audio world as bi-wiring, it's just a type of terminal (basic electrical connector) that takes raw wire from a two-conductor cable (you have to match red with red and black with black from each set of terminals).
Wisoonsta
which i literally have to shove-in wires to connect it to the old cd/cassette music system.
I may be mistaken, and if that's the case then I apologize ahead of time, but I'll assume that you're only familiar with speakers that connect through things like 3.5mm headphone jacks. Most "hi-fi" home audio speakers, like the ones you're inquiring about, are connected with raw wires shoved into terminals, even today. You either shove two wires (usually) into a "spring clip" or "binding post" and then make sure they're secure, or you can make or buy cables terminated with metal pins or "banana plugs" that simplify connecting and disconnecting from these terminals, respectively. The speakers need to be electrically powered somehow (right?), and these cables (which often resemble other power cables) are needed to power the speakers with the audio signal (all at once--the signal actually provides the power). A certain type of device is required to amplify a signal enough to power the speakers, and naturally they're called amplifiers.
If I'm not mistaken, the speakers that you're accustomed to generally have another power source, such as a power cable (or cord) that plugs into an electrical outlet, or maybe even batteries. Such speakers are either part of a system that includes amplifiers or have amplifiers built right into them, which you can tell because they plug into an outlet and receive the audio signal separately from a 3.5mm cable (TRS), RCA stereo cables, or even something like USB. The Sony SS-D302 is a completely different--but still extremely common--type of speaker that needs a separate amplifier (often built into a multifunctional unit called a receiver or one like your parents' old music system) to work.
Wisoonsta
Is it possible to install some sort of USB or 3.5mm Stereo headphone jack or chord? If so, how?
These speakers can't power themselves without an amplifier (please don't plug them into an electrical outlet!
), so you'd have to install one, like this:
http://www.parts-express.com/pdf/ThePerfectlyPortableB652.pdf
Or you could partner them with a small amplifier if you don't already have one that can take a signal from an outside source (e.g. computer, MP3 player), such as the following:
http://www.amazon.com/LP-2020A-Lepai-Tripath-Class-T-Amplifier/dp/B0049P6OTI
Check out the picture of the rear panel--there are two sets of spring clips to connect to your speakers and a couple of jacks for the audio signal (3.5mm and RCA). And it plugs into the wall for power.
