As in the title what problems are you having with your Epson Projector:
Mine are:
The problem:
OK Have many checked the 2D to 3D converter system??
I find that I keep getting a left eye field that is warped, and bends along the lower 1/3 of the picture to the right.
I have a call into tech support about this.
I have seen it on all the 3020s I have had so far.
The answer from Epson:
"As for the warped 2D to 3D conversion in the left field, this is a normal artifact of the conversion process. We are taking a 2D image and giving it depth, in order to do this we are superimposing 1 image on top of another. the "warp" you are seeing is part of the second image that gives the 1st image depth. It is specification and nothing can be done to correct it. You may also see it on the right side or not at all, the artifact you are seeing may vary based on the content that is being converted to 3D.
As long as you do not see this artifact with Blu-Ray or Broadcast 3D the hardware is OK."
So a right field that is straight and warped left field is normal and OK??
That makes NO sense to me, two pictures left and right, yes, and a shift to make it look like 3D also OK but to distort the lower 1/3 of one field does not compute to me.
I was also concerned with lamp failure as mine failed within 3 weeks.
They replied:
"There are no known issue with the lamp or the life, this is the same lamp used in the PL HC 3010 and they are well over a year old now with a very low failure. Due to the nature of UHE lamp technology some lamps can fail prematurely."
I seem to have seen a few failures posted here, a higher number that just one or two.
I am starting this tread in responce to this post:
"Is there no way to set up a poll as a new thread?
Infact I'd like to see a poll for all the problems people have been experiencing with the 30,50,60, 10 & 20 line of projectors so we can see how many people are in fact having such problems and then link Epson to the poll. It's about time someone from Epson showed their face on here and answered some of the concerns directly."
Rich
Mine are:
The problem:
They replied:
Rich
