Hello everyone,
I bought a new house recently and my neighbour bass is killing me. Yes i've talked to him and he's a jackass..
My house is a two story level and fortunately, the only place I hear his bass is in my garage, which I don't really care, and on the second story, the room above my garage with is a small loft where we go to relaxe.
My room is a small square 15 X 11 ft and the 15FT wall is facing my neighors. We have about 10 ft between my house and his house.
Currently, the Dry Wall used is only 1/2 drywall with normal R20 insulation.
I was thinking at getting rid of the drywall for only the 15ft wall (the wall facing his house) and replacing that with QuietRock 545.
I'm about to invest a good sum of money..
Do you guys think that after replacing my drywall with quietrock 545 it should solve my issue ?
Any help is appreciated..
Ok, my drawing skills are not high but on the left it's my 15X11ft room above my garage and on the right it's my neighbours 10 ft away with his subwoofer facing my house.
The wall in RED is the one i'm about to remove the gypse and replace it with quietrock 545
