I live in a small town in Oklahoma. One of the channels does not broadcast in dolby digital. What is the perfered audio format when you can't get dolby digital. I was using direct but the I read that direct does not use bass management, and sets front speakers to full. So what would you use?
Is there a way to keep whatever I chose permanent. I have changed it, but it always goes back to direct. Will it when, I change channels go back to dolby digital if that is the format being used on that channel?
Thank you Bob
Thank you Bob
