Hi all, I may have to replace my old receiver and speakers with a new 5.1 (7.1 is overkill for me) receiver and speakers sometime this year. I have a few questions i'm hoping you can answer. I want my system to sound good, but i'm not an audiophile. I don't have a budget just yet.
1. what ratio of power between receiver and speakers should there be? 1:1 or should the receiver always be more powerful than the speakers? is there an ideal ratio?
2. what cost ratio should I spend between the receiver and speakers?
3. what are some good brands of receivers and speakers?
4. what should I make sure of when matching speakers with the receiver?
5. is there a way I can have my digital TV box plugged into the receiver and TV using the HDMI port? if I plug the digital box into the receiver's HDMI, I don't want to always have to watch TV through the receiver/speakers. for normal TV watching, i'll most likely just want to listen to it through the TV speakers. will I have to plug the digital box to the TV's HDMI and send audio cables to the receiver? or is there an HDMI splitter? any other solutions?
6. any other things I need to consider?
I think that's it for now. thanks for any help
