AVS › AVS Forum › Video Components › Home Theater Computers › Anyone know a good cooler for a silverstone LC-10B case? The old version...
post #1 of 14
The stock intel cooler on my 3570k sounds like a full throttle Xbox 360. I'd like to replace it with a better, more silent cooler. I don't want to go with liquid cooling.
That being said, so many of the popular recommendations won't fit in the LC-10B case. I can just barely fit a 7950 card in there...i can't even screw the lid on because the PCI-E power cables on the top of the card extend just a bit too high, and that is about 5" tall.
My motherboard is an asrock z77 extreme 4.
Anyone have a really good recommendation?
Thank you!
post #2 of 14
It's prob your PSU making noise.
Did you try lowering the fan setting ?
Usually stock intel coolers are very quiet and dont sound like your describing
post #3 of 14
I'm pretty sure it is the CPU fan...when I built the computer I had the PSU outside of the case for a while during testing and it was easier to hear where the sound was coming from.
I do know that the bios on the asrock is set to "full on" on the fan, so I guess it is running at full speed, but when I tried to change it in the bios, it didn't seem to do much.
post #4 of 14
Lower the setting will quiet it down for sure. Try 4.
Up your target temp 1 degree too. ( makes huge difference ).
post #5 of 14
I lowered the fan settings via the Asrock utility software to 4 as you recommended. It made a HUGE difference. It doesn't sound like a 360 on full anymore. It sounds more like a 360 turned on at teh dashboard at rest.
That being said, it isn't silent. I would like to make it quieter yet.
I'm also concerned about the temps. By lowering the fan to 4 it keeps the CPU much hotter-at about 51 degree Celsius.
Any recommendations on a silent cooler that would fit in my case and motherboard?
post #6 of 14
I've run CPU at 51 degrees (and hotter) for 24/7 use for years. I'd take the bet it would last a half decade with anyone that wants it.
That said,
What clearance do you have for space?
Coolermaster makes good cheap but effective CPU coolers.
Or this: ($9.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118139
ZALMAN CNPS7000V(AL)-1-PWM 92mm FSB (Fluid Shield Bearing) Silent Pure Aluminum CPU Cooler with enhanced performance and silent operation
If you have more space you can probably get something better.
I have a 512 EVO coolermaster and it's great. $25 and it's performance is awesome.
Probably too big for you case though.
post #7 of 14
Btw- I have an asrock Z77 + 3570k in my HTPC with stock cooler on level 4 target. I adjusted the default CPU temp up (+1) Celcius.
It's nearly silent and it is in my bedroom. It's in an Antec300 case. It rests on the floor in my AV closet (no door on it) not far from me.
I think your sensitive to the noise or you got a bum intel cooler. Mine is quiet. As is most of them I build.
But nothing wrong spending $10 on that above if you want it. It should work well. It fits smaller cases so if you have a lot of clearance there might be a better choice for you. I did not look up your dimensions I just chose a fan I thought would fit.
post #8 of 14
I think that you're right...I am sensitive to noise. The PC is also about four-five feet from where I sit. It is possible, also, that the case doesn't do a good job of insulating the sound. there is no sound dampening material.
I do notice the sound from the cable company-provided dvr's and it bothers me as well.
post #9 of 14
Cooler Master GeminII S524.
post #10 of 14
I was looking at that one, but my concern is with the ram. I have the corsair vengeance ram, and it is taller than the clearance that cooler gives.
post #11 of 14
No problem if you orient the heatpipes toward RAM.
post #12 of 14
The master has spoken ^
post #13 of 14
Alright...thanks for the input, guys. Ordered the cooler and we'll see how it fits this weekend.
post #14 of 14
