AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Problem with New Panasonic VIERA TC-P55VT50 55-Inch Plasma TV
post #1 of 3
I just purchased a new Panasonic VIERA TC-P55VT50 55-Inch Plasma TV. It has a thin blue line on the left edge (facing tv). Is there a problem and do I need to calibrate to fix??? do i need to return?
thanks
post #2 of 3
Does it remain no matter which source you are using? If using HD TV source, does it remain on every channel?
Can you snap a pic and post?
post #3 of 3
Ho Thanks. Actually, it is only when we are using the THX picture feed. It isn't there for any other feed.. so I'm thinking that when I'm viewing a DVD it will be gone. I haven't had time to try that yet..
