AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Down to 4 tvs...I don't know which to get.
post #1 of 9
Hey guys. I have 4 tv's in mind around my 1500+/- budget. Now, I can't figure out which one to get.
Samsung UN55ES7500
LG Cinema Screen 55LM8600
LG Cinema Screen 55LM7600
Sony BRAVIA KDL55HX750
Any advice? Thanks!
post #2 of 9
Samsung UN55ES7500
Any advice? Thanks!
LG LM7600. Done and done.
The HX750 is subpar, the ES7500 is overpriced, the LM8600 is nonsense.
post #3 of 9
I assume you are calling the LM8600 nonsense because the dual core CPU in no way justifies the price difference between it and the LM7600.
post #4 of 9
Absolutely.
post #5 of 9
Samsung UN55ES7500
Any advice? Thanks!
I would pass on LG, inferior PQ IMO.
post #6 of 9
Of the models in question you believe the LM7600 is inferior to the ES7500 and HX750?
I'd agree with that assessment on the LM8600, but not the LM7600.
post #7 of 9
I have not seen an LG TV i liked, nor read a review about an LG tv that is better than all other TVs in its certain class. The ES7500 is a solid TV at that price, that would be what I would pick.
post #8 of 9
I can respect your assessment of preferring the Samsung's performance. I call the ES7500 over-priced because, well it is.
If going the Samsung route is your/his choice, then go for the ES7100. The only extras the ES7500 gives you is the always useful integrated cam and a higher "CMR."
post #9 of 9
Thanks for your replies. Still debating. If I debate long enough maybe the prices will drop.
