Well seeing as the snowball in already rolling down the hill, I might as well not try and stop it.
I have my order in for my TD15's/4550/Seos 12 (hopefully 15 but we'll see), for my front build. I am currently running Axiom QS8's for my side surrounds which I have been very happy with. One of the things I like the most about them is their quadpolar design that allows some placement flexibility while still sounding very good. I'm running two rows of seating and have my side surrounds placed about 3' behind 1st row and 2' in front of the second. I can't go with 2 rows of side surrounds, so the rear seating isn't going to be optimal (but I don't sit there so.........
) That being said, they do a good job of immersing both the front and rear row.
I don't want to give up the immersive factor the QS8's provide. Everyone likes the SEOS as they are more direct than dome tweeters. Wouldn't this be detrimental when using as side surrounds? Now if I had one row of seating I can see wanting a direct radiating speaker, but when trying to cover a wider range, aren't bi/quad polar designs more effective?
I'm debating on a TD10m with SEOS12/4550 to match the mains. The kicker is; I need to keep the box depth to around 6" as I want as much room as possible with my narrower room. I was thinking about an angled box mounted just underneath my sofit (8" deep at the top and 4 or 5" deep at the bottom) pointed down towards the listening position. I'm just concerned the 12 isn't going to have a wide enough pattern???
Thoughts?
) That being said, they do a good job of immersing both the front and rear row.I don't want to give up the immersive factor the QS8's provide. Everyone likes the SEOS as they are more direct than dome tweeters. Wouldn't this be detrimental when using as side surrounds? Now if I had one row of seating I can see wanting a direct radiating speaker, but when trying to cover a wider range, aren't bi/quad polar designs more effective?
Thoughts?
