I have owned the Oppo a few days, and so far, I'm a bit disappointed. Perhaps I had too much
expectations after seeing all the glowing reviews. As a Blu-ray player, the Oppo works
as advertised. Discs load quickly and play without a hitch (the ones I've tried so far anyway).
The video quality is fine, although not a significant advance on previous players. The 4K interface
seems a classic instance of gamesmanship, when no one yet has a 4K display.
Much else seems a work in progress to me.
1. The HDMI inputs don't work at all. I tried 3 different sources -- my cable box, a Mac mini with HDMI,
and a Samsung Blu-ray/HD-DVD player. In all three cases, I get either a blank screen or a green screen.
When $200 receivers get HDMI switching right, it is embarrassing that a $1200 player can't get this right.
2. The audio leaves much to be desired. The sound is grainy and bright. I hear from other's experience that
it improves with break-in. I certainly hope so. One possible reason is that the Oppo does not upsample,
surprisingly, in contrast to almost every other CD player out there. As a comparison, I tried the Cambridge
Audio 752BD, which shares the same video architecture as the Oppo 105. The contrast could not
be more stark. The CA player has a smooth refined sound that is engaging to listen to. It uses 8
Wolfson 24-bit D/A converters and upsamples to 24/192.
3. The streaming interfaces work, but are clunky. The Netflix streaming interface seems poorly
designed, with an MS-DOS like garish screen and chunky font. Oppo should invest $100 in an Apple TV,
and learn how to design an elegant interface to Netflix. Netflix streaming works reliably once it starts
up. Media streaming works as well, although the interface again is poorly designed. You have to scroll
through long lists of albums. Again, Oppo should take a cue from well-designed interfaces, like the
Squeezebox Touch and iPeng HD on the iPad.
4. The asynchronous USB interace works, but takes forever to start up. When set to USB input, the 105
goes into a "hunt" mode, displaying USB input for perhaps 5 minutes before the USB DAC sign illuminates.
Once this happens, it starts to play fine. Not very useable IMHO.
My hope is that Oppo takes these criticisms seriously, and issues a firmware update that fixes these
problems. Most of these have been noted in various threads, but perhaps not collected in one place.
As always, caveat emptor.
I think they are all competent at what they do and the Oppo does offer a few features not found in the competition. So, in the end it will come down to features and what sonic characteristics you PREFER as they all implement different DACs.
