AVS › AVS Forum › Audio › Speakers › I have $2000 to spend on speakers for a 5.1 systems to go with a Pioneer VSX-23THX. Any reccomendations?
I have $2000 to spend on speakers for a 5.1 systems to go with a Pioneer VSX-23THX. Any...
post #1 of 4
Hey all, I am finally upgrading my speakers from the current Theater in a Box ones I have been using. I have a Pioneer VSX-23THX and a paradigm bass, so I only need 5 speakers. I will primarily use my system for watching TV, Movies and playing video games. My system will also be located in my living room, which is pretty standard. Which speakers would you recommend that would give me the best value for my money. Thanks for the help.
post #2 of 4
You're question is too vague.
You need to add some details, like room size, whether or not you want to buy locally, online, ID etc.......
post #3 of 4
Also budget range, space/size limitations, etc.
post #4 of 4
+1
Yep. Room volume (cubic feet). Do you have room for towers, or just bookshelves? What about the surrounds? Do they have to hang on the wall, or can they go on stands?
And also, which model Paradigm sub do you have to match with your speakers?
  Back to Forum: Speakers
  • I have $2000 to spend on speakers for a 5.1 systems to go with a Pioneer VSX-23THX. Any reccomendations?
