The dilemma:
I'm in the market for a new TV, plasma, of course. I wanted to know what some of your suggestions are in regards to the differences between all these models. I have leaned towards the GT50, with a couple features that i like. The filter, which will kill some of the ambient light that come sinto my living room and cut down on reflections; the brightness of the set, which is supposedly ( I havent seen the model in the store) one of the brightness plasmas aside from the new 2013 ZT series; also the dual processors.
My background:
I have a LGPM6700 right now, very reflective, and the colors seem dull. Quite honestly I made a bad choice when I bought this TV. Problems with AV SYNC, and firmware updates that killed it in the beginning.
My choices were limited when I purchased this as it fit into my price range and the Panny U50 model seemed really dim and dark even after shutting off the power saving modes.
So I narrowed down to these 3, and wanted everyones opinions based on these 3. I know not much is known about the P60ST60 yet, and i dont know if I'd be able to notice the difference between the GT50 and the ST50? (Brightness, PQ, etc)
I value everyones insight and opinion, please let me know what you think.....
My background:
