AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › S60 vs ST60
S60 vs ST60
post #1 of 4
Just looking for pic quality not any of add-on stuff...Between the S60 and the ST60 which one would be the better deal...
post #2 of 4
Hard to say until they are reviewed, only reference would be last years u50 compared to st50, blacks were close but there was a pretty big gap in picture processing and light output. And the abl was much more aggressive on the u50. Perhaps this year will be different tho
post #3 of 4
Well, if the PQ is exactly the same and you're not interested in Smart/3D features, then I think it's an easy decision.
Edit: As chunon said, it will depend if the PQ is equally comparable or if there are significant differences.
post #4 of 4
Thanks guys!!
