Originally Posted by
jdsmoothie
The E200 actually does use spring clips, and while the new speaker posts on the E300/E400 cannot use banana clips, they are designed for more easier bare wire use of which the vast majority of buyers of these "lower" models likely use. You simply depress the post cap in and insert the bare wired into the post hole and release the cap.
Call me crazy, but I LOVE these connectors if they're anything like those found on hi(gher)-end/output speakers/subs, like these (mouse over the connectors):
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-472
Very robust, fantastically easy to use and secure...and will take up to 10G wire for the overkill set. Personally, I've never understood the rabid obsession banana plugs get...they are MUCH more prone to popping out before a secure bare wire connection, are just another link in the connection that can fail, are not more likely to achieve a solid connection, and cost more money.
Well, I guess I DO get it: sounds like a AV hobbyists wet-dream after the aforementioned.
Love em.
James
Edited by mastermaybe - 3/12/13 at 10:08am
