sub at MLP at 75db for crawl on pressboard on top of crates.jpg 2759k .jpg file
crawl sounds best 16 inches from ceiling 83 db in doorway closed door.jpg 2108k .jpg file
Spiderman(?) “sub crawl” The room is 9’10” wide 11’ deep 8' ceiling. less than 900ft3. I’ve been “REW”ing (great thread) and for a perhaps constructive break reverted to basics and set up a sub crawl, with my Klipsch sub 10. I put my Onkyo 270 on manual level calibration to the sub tone output, and set the volume to get a spl reading of 75(or so) with the rs meter just above the center of the sub.
This about as close to MLP as I coud get.
Picture 1 is the set up.
Then I crawled, holding the meter while I did. Picture 2 is the doorway is where it sounded best/loudest 84 db. My ears are 63 inches from the ground. There IS space to place the sub over the door on a solid (or not) (or modified) (suggestions?) platform.
The width is is 40 + inches and depth 27 or so. There is no WAF. The sub measures 16 wide x19 deep so there’s some wiggle room with respect to the port and how close it is to a surface.
Question for the seriously/ terminally addicted/infected: How about 2 15''s in an IB construct vented to te attic crawl space? I can build and power anything.
