AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Hello! My First Post, About AVR-2312CI
post #1 of 5
Hello There, i have being using the denon AVR-2312CI for two months now, somehow i did something and i am not able to listen an stereo source with the subwoofer on, what do i have to do?, Any tips will be greatly appreciated!
post #2 of 5
After running Audyssey, you need to reset your FL/FR speakers to SMALL and raise their crossovers to 80Hz.
Also note there is a dedicated Denon AVR-XX12 Owner's thread linked in my sig. Review posts #3-6 in that thread for more helpful information.
post #3 of 5
Thanks a million tha seem to resolve the issue!!!
Is there any difference now in the sound because my front speakers are large, i guess i have a lot to learn, Thanks anyway
post #4 of 5
No ... note that LARGE/SMALL refers to "bass management" and not the physical size of the speaker ... they should generally ALL be set to SMALL/80Hz if capable of going below 80Hz.
Review the Audyssey 101/FAQ Guide linked in my sig.
post #5 of 5
Thanks you are officially my friend!!
