I have worked on this for months - not a lot of spare time to research in my job. I am a new builder - so this is going to be a spring break project for me. Please look over everything - I am a little confused on the slots available on the motherboard. I have a TV Tuner card and a wireless adapter - will they both fit on this board? The tuner comes with a remote that I can use on windows 7 until I find one that works better. I know some of this might be a little overkill - but there is always a chance I will add on to it so I wanted to make sure it s good in the future. Is there anything I left off??? Going to use this to cut out cable and record over the air TV as well as watch netflix, Hulu...
[PCPartPicker part list](http://pcpartpicker.com/p/HVhS) / [Price breakdown by merchant](http://pcpartpicker.com/p/HVhS/by_merchant/) / [Benchmarks](http://pcpartpicker.com/p/HVhS/benchmarks/)
Type|Item|Price
**CPU** | [Intel Core i3-3225 3.3GHz Dual-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80637i33225) | $132.90 @ Amazon
**Motherboard** | [ASRock Z77 Pro4-M Micro ATX LGA1155 Motherboard](http://pcpartpicker.com/part/asrock-motherboard-z77pro4m) | $109.99 @ SuperBiiz
**Memory** | [Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory](http://pcpartpicker.com/part/corsair-memory-cml8gx3m2a1600c9) | $59.48 @ Amazon
**Storage** | [Samsung 840 Series 120GB 2.5" Solid State Disk](http://pcpartpicker.com/part/samsung-internal-hard-drive-mz7td120kw) | $116.95 @ Amazon
**Storage** | [Western Digital WD Green 2TB 3.5" 5400RPM Internal Hard Drive](http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd20ezrx) | $102.98 @ Outlet PC
**Case** | [Silverstone SST-GD05B-USB3.0 (Black) HTPC Case](http://pcpartpicker.com/part/silverstone-case-sstgd05busb30) | $114.31 @ SuperBiiz
**Power Supply** | [Antec EarthWatts Green 380W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply](http://pcpartpicker.com/part/antec-power-supply-ea380dgreen) | $47.98 @ Outlet PC
**Operating System** | [Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)](http://pcpartpicker.com/part/microsoft-os-gfc02050) | $89.98 @ Outlet PC
**Other**| Hauppauge 1229 WinTV-HVR-2250 White Box for System Builders Dual Hybrid PCI-E TV Tuner Board| $96.11
**Other**| Rosewill Wireless N Dual Band Adapter IEEE 802.11a/b/g/n PCI Express Upto 450Mbps Data (RNWD-N9003PCe)?| $34.73
**Other**| Pioneer BDR-2208| $69.99
| | **Total**
| Prices include shipping, taxes, and discounts when available. | $975.40
| Generated by PCPartPicker 2013-03-06 12:13 EST-0500 |
Type|Item|Price
| | **Total**
The actual failure or success rate is completely unknown as the companies aren't going to disclose this information.
1866mhz in dual channel and 8GB is "preferred" (At least by me
