AVS › AVS Forum › Video Components › Home Theater Computers › Please look over build before I hit the purchase key...
Please look over build before I hit the purchase key... - Page 2
post #31 of 34
Originally Posted by macks View Post
Assassin's "Forget it." posts always make me laugh.
We are arguing about something silly again though.
post #32 of 34
Dual channel memory is critically important in certain video playback applications such as madVR and SVP.
Single channel: 64-bit data path
Dual channel: 128-bit data path
(If you are familiar with gaming cards, you know what that means.) Personally I recommend DDR3-2133 2 x 4GB such as G.SKILL F3-2133C11D-8GAO, ~$59, not terribly expensive (DDR3-1600 2 x 4GB costs ~$50 anyway), improving the performance of the above applications considerably, and future-proofing (2133 MT/s is the lowest transfer rate of the DDR4 specs, btw). You shouldn't worry about compatibility, it's compatible with ASRock Z77 Pro4-M (and perhaps almost all Z77 mb).
Edited by renethx - 3/7/13 at 4:26am
post #33 of 34
Thanks for intelligent post^
I always knew it mattered but your expertise and explanation is appreciated. I do side with you since the faster memory clock is not much more. I just bought some of that memory and for a couple bucks it's a no brainer even if you don't "need" it.
Dual channel does not cost more (perhaps couple dollars)
Faster Memory does not cost much more (Few dollars also)
If your already spending $50 on RAM why not spend $55 or $60 for the better kit. It just saves you later from having to upgrade. I just swapped out my 3570K/Z77 HTPC from DDR1600 to 2133+
post #34 of 34
@ OP
How did you make out ?
