Back in 2002 I made a DIY rear center setup using an old Dolby pro Logic decoder fed with the main processors rear L&R inputs. This was a somewhat popular kludge of the day.
Question now, is this doing more harm than good in my room? I am concerned about phase cancellation / combing.
Thechnical notes:
My main processor is a Lexicon MC8. The rear center processor is a Lexicon CP1. The MC8 is actually modified to provide a pre-volume 8 channel out. I use the rear L&R pre-volume signals to feed the CP1. I also have a VCA box (with a copy of the MC8 VCA circuits) that is connected to the MC8 VCA control buss so the CP1 output tracks the MC8 volume control. This goes between the CP1 center output and the rear center amp. A bit overkill but I thought the CP1 decoder may have a better S/N with full level input signals versus taking the feed from the rear amp inputs. Note that the 8 channel pre-volume out is also for my metering displays.
I would appreciate your expert opinions as well an anyone else on this matter.
Thechnical notes:
