I've discovered recently that my Panasonic BDT110 has some sort of built in overscan that I cannot turn off. I was zooming an open matte 4:3 DVD yesterday to create a faux 1.85 presentation (the correct OAR) and I discovered that all 4:3 DVDs are losing picture on the sides until I zoom them. See:
http://i.imgur.com/GVRYIcD.jpg
http://i.imgur.com/NPSQfqF.jpg
Overscan is off on my TV. Those are the exact same frames, yet when I am not zooming, the image is being cropped on the sides. If you measure the first image, the AR is about 1:29:1, when obviously it should be 1.33:1. I figure the BD player does this because it expects your TV to be overscanning as well. Since TV Overscan only affects the top and bottom of a 4:3 image, it will make a 1:29:1 image into 1.33:1. But that way I'm losing information on all 4 sides. I would much rather turn this feature off and be able to see the 1.33:1 image that is actually on the disc, but I cannot find any options relating to it in the set up menu or manual. My Panasonic BD65 does the same thing too.
Is there any way to turn it off, or perhaps a known brand of players that does not do this? Can anyone check to see if they experience the same thing? This only works with player zoom function, not TV zoom. I have tried turning off the upscaling and sending the DVD data to the TV as 576i (the native resolution of the disc) instead of 1080p but this makes no difference.
TV is Panny GT30 via Onkyo SR508 receiver
