Originally Posted by
cshawnmcdonald
Is there anything that I can do about the PQ? Am I missing something obvious? I think I have a 12Mbps-down ISDN connection. Does more bandwidth equate to a better picture?
Yes, more bandwidth equals better picture, to a point. 12 Mbps is more than enough for most services; I believe that VUDU's HDX video is currently the highest bit rate content at 9 Mbps. But just because your service has a nominal rate of 12 Mbps doesn't mean that you'll get that on your connections to the providers.
What are you watching? The best PQ on Roku comes from services like Netflix, VUDU, Amazon, Hulu Plus and HBO Go. I personally don't use the free stuff; a lot of that which I've sampled isn't of the greatest quality. If you want to see the best that Roku 3 can do, install the VUDU channel, run it and play one of the freebies at HDX quality. (You may have to create an account to do this, though you don't have to to view freebies on the web site).
Wreck it Ralph has a few free featurettes and
Rise of the Guardians has a great 8 minute extended preview. (You might first select the My VUDU tab, drill down to Info & Settings and run the Network Speed Test; that will tell you if you can sustain the 9 Mbps required for 3 bar HDX).
