AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › *Official* Roku 3 Streaming Player Thread
*Official* Roku 3 Streaming Player Thread - Page 10
post #271 of 1724
Originally Posted by michaeltscott View Post
Yeah, I know, mine too. It's always a gradual rollout, often over a few weeks; bad idea to update everyone's firmware at once just in case you got something wrong. No matter how much testing you do, customers in the field will use it in subtly different ways that you didn't test which sometimes expose bugs.
There is some suggestion (here in the Roku forums) that Roku 3s have been arriving with 5.0 b7070 installed and then downgraded to 5.0 b5861, but some people have reported being upgraded to b7070 recently. Maybe they're being "upgraded" to what it should have started with.
Thanks. I am just use to the way the PS3 just forces mandatory updates that end up messing up a lot of systems. Does it just update automatically or do I have to keep checking?
Gear mentioned in this thread:
post #272 of 1724
The Roku will automatically update itself; it checks at least once daily to see if a new update has shown up.
post #273 of 1724
Originally Posted by rwestley View Post
Has anyone had issues passing Dolby 5x1 audio. I can't get Dolby Plus to work. I have the Roku set on Surround. No help from tech support.
What player are you using, Netflix or VUDU? What title or titles have you tried? If on Netflix, did you go into the title's Audio & subtitles menu and enable DD+ sound? Are you sure that your AVR can decode DD+? What's its brand and model? What happens when you try to play a title with DD+ 5.1 sound?
post #274 of 1724
I have no issues passing DD+ from my 2XS to my Onkyo NR616. Is your Roku connected directly to your AVR? It won't pass 5.1 if it's connected straight to the TV and then out to the AVR.
Edited by Buckeye911 - 4/3/13 at 3:20pm
post #275 of 1724
Anyone else having the problem where the Roku UI becomes a bit laggy after about two weeks? It does not affect the apps and they dont crash. A quick reboot fixes the lag.
i dealt with slow load of apps for a while and then talked with roku tech support and they suggested setting up static dns in my router. it's worked fine since.
static dns 1 8.8.8.8 and static dns 2 8.8.4.4
i was informed that these were google dns numbers. roku tech support said this information is on their site, but i could not find it then or since.
and as a side note i have roku 2 and i have it set up on a green surge protector switch that turns off all my parasitic loads when i turn off my avr receiver. in other words... it turns of the power to my roku, bluray and cd player every time i turn off my receiver. i believe keeping the roku on all the time shortens the life of the unit. i bought my first roku the year they came out, i believe in 07 and it burnt out.
post #276 of 1724
Burned out how quickly? I got the ROku 2 XS when it was first released(Summer 2011) and so far has been fine while on 24/7.(it only draws around 2 watts) Although I do have a four year extended warranty on it from BestBuy. But I would be surprised if I am still using it in two more years anyway.
My Roku 3 is on 24/7 as well although doesn't that use more power than the Roku 3?
post #277 of 1724
That's tech supports scripted answer to every solution to use Google DNS. DNS has nothing to do with a laggy UI. I rather stick with OpenDNS which has more features anyway.
post #278 of 1724
Yes to all of the above. I also have the Netflix app on the Oppo 103 and it passes DD+5.1 with no problem. I also had no problem with previous Roku boxes.
post #279 of 1724
Some of them were not yes or no questions biggrin.gif. Again, what title or titles have you tried (Netflix) and what happens when you try to play a title with DD+ 5.1 sound?
post #280 of 1724
Originally Posted by earthbound View Post
I'm hoping a firmware update will add lossless audio playback, flac or whatever, but $99 for what you get is still a great deal.
If you use the free Plex music server on a PC and the Plex client on the Roku you can stream all the FLAC files you want. I have hundreds of albums on a hard drive and Plex recognizes and plays them, even showing album art.
post #281 of 1724
That's cool... Do you know if the Plex client can handle high resolution FLAC or gapless playback? Thanks, in advance.
post #282 of 1724
I currently have an old WDTV Live Plus and I've been considering an upgrade. I have a wireless usb stick plugged into one USB port and an external HD in another. I stream some content and play files directly off the HD as well. The thing I like most is that it plays any file that I throw at it, and I'm worried that a Roku (3) wouldn't give me that same experience.
Can anyone advise if this would be a wise purchase, and/or what I'd need to do in order to continue the same setup I have now?
post #283 of 1724
Sorry. It is connected directly to the receiver. I also tried it through the HDMI input on the Oppo 105. The funny thing is the I have the older Roku and it passes DD+ 5.1 sound.
One film I tried was "The Art of Flight" I get Dolby plus with the app on the Oppo but just stereo on the new Roku. I try a few more things tonight.
Than ks.
post #284 of 1724
Which older Roku? You mean a 2nd gen Roku (Roku 2 (XS or XD), Roku LT or Roku HD (2500))? If, when you hook that up the same way as you have the Roku 3 hooked up you get DD+ 5.1 sound out of Netflix into your AVR?
That's strange--The Art of Flight does not seem to feature DD+ 5.1 sound.
post #285 of 1724
On Vudu "The Art of Flight" has a free sampler that has DD+ 7.1
I think it is under the 7.1 collection.
post #286 of 1724
Actually I looked at The Art of Flight on Netflix and it's listed at "SuperHD" and "5.1". Not sure what you're looking at.
post #287 of 1724
Correct that is what was stated. SuperHD and 5.1. I just tried the Roku again and there was a firmware update. When the unit came back on Dolby 5.1 plus is now working.
Thanks for the suggestions. I don't know what the firmware number was when I received the box but the update seems to have fixed the issue. I am wondering if it was some kind of HDMI problem with the earlier firmware.
post #288 of 1724
That is so strange. I've checked in my Roku 3, my PS3, my WD TV Live, my TiVo Premiere and the Win8 Netflix app and they all show The Art of Flight as being Super HD but with no 5.1 sound. Can anyone else see The Hunger Games on Netflix's site as something you can add to your IQ? EDIT: Looks like it might have been added to the US region recently, "HD on Your TV" (720p only, no HD in PC players), no 5.1 sound.
post #289 of 1724
No thanks to Epix. Everything from Epix is 720p HD on Your TV bull crap. You in Canada got it made for movies because you don't have HBO, SHOWTIME & EPIX grabbing most of the movies. Now I see why you use Unblock US. I can't keep changing my DNS servers all the time on my Router is a PITA.
post #290 of 1724
So, does everyone else who looks at The Art of Flight in the Netflix player browser (on Roku 3 or elsewhere) see it as having 5.1 sound?
post #291 of 1724
Anyone seen this glitch?
It's happened a few times. Usually moving the remote up or down makes it act right. But today it was totally frozen. Had to reboot.
post #292 of 1724
Yep, seen that glitch, too.
post #293 of 1724
My cable provider lets Netflix used HDSD. The Art OF Flight has 5.1 under audio Must be checked. It only worked for me with the latest firmware update.
post #294 of 1724
Which Art of Flight is being talked about? There are two of them,. One is an 80 minute show that has 5.1 audio and stereo audio as options. The other one is a seven episode series that only has stereo audio. They both deal with snowboarder Travis Rice.
post #295 of 1724
Yup. I assumed it was an HDCP handshake issue, as I encountered it upon switching AV inputs.
post #296 of 1724
A suppose firmware update suppose to fix it yet I can't download it. It just says its up to date. They must be pushing the update to just a handful of users.
post #297 of 1724
For me there's nothing to check: "Audio & subtitles" has a single item under "Audio" being "English Stereo". I've checked this on Roku 3, TiVo Premiere, PS3, WD TV Live and Win8 Netflix app (I'd check a few other device but it seems pointless). It's very strange that it shows up in 5.1 sound for others but not for me.
post #298 of 1724
Plex does handle high resolution FLAC without any problems. I've played a number of them that I've downloaded from HDTracks.com. They sound great. In regard to gapless playback, I'll have to check later today, as I haven't yet played a live album where the lack of gapless really becomes obvious.
post #299 of 1724
The Roku 3 doesn't decode FLAC so the Plex server must be transcoding it to something lossy.
post #300 of 1724
Well, that was my next question, so thanks for pointing that out. However, just because the Roku doesn't decode FLAC doesn't necessarily imply a loss of quality. It's possible, similar to how other streamers handle this, that the server is simply transcoding to LPCM without loss of quality and sending that over the network to the Plex client.
