AVS › AVS Forum › Audio › Speakers › Question about speaker impedance
post #1 of 6
Hey guys, im picking up a pair of vintage klipsch KG4 speakers this weekend.. i found them locally for a great price and ive heard good things about them.. my question is about matching them with an amp.. this is going to be my first hifi setup and i dont know much about impedance at all.. the specs for the speakers say 6 ohms nominal impedance and 100 watts continuous(500 watts peak), but the amp i want to get is the marantz pm5004 which has impedance of 8ohms (35 watts), and 4ohms(45 watts)... my basic knowledge is that i would need an amp that is 3ohms? not sure if im wrong so any help would be greatly appreciated... i was really looking foward to pairing the marantz with these speakers
post #2 of 6
You're fine, go ahead and rock out.
post #3 of 6
Just about every known receiver and amp is compatible with speakers with 8 ohm or 4 ohm or anything in between. Those 6 ohm speakers will work fine with the Marantz.
post #4 of 6
You may be thinking of the scenario in which two speakers are connected "in parallel" to the same amplifier channel, in which case their combined nominal impedance would indeed be 3 ohms. Fortunately, you are just over-thinking things. wink.gif If your integrated amp has two separate channels for stereo left & right, as I believe it does, then all you need to do is connect one speaker to each channel, and you should be perfectly fine (6 ohms for each channel).
By the way, speakers tend to vary in impedance depending on the sounds they're reproducing anyway, so in basic terms everything doesn't have to be SO precise. As for power ratings, the speakers' ratings are how much power they can take (supposedly), while the amp's rating is how much it can supply (again, supposedly, and usually per channel). In practice, the amp will provide only as much power as you need at any given moment, which for most people is not very much on the average, like maybe 1-10 watts most of the time (with a higher power rating still being important for dynamics and certain really loud sounds). The speakers and amp do not have to be matched in this regard, either--those are merely their independent, respective limits.
post #5 of 6
Many AVRs are rated for 6 ohms minimum and they'll shut down in a heartbeat with a 4 ohm load, or even a nominal 8 ohm load if the particular speaker has impedance dips that go close to 4 ohms. Since the receiver the OP is considering is 4 ohm rated he should be OK, but you can't always assume so. B&W for one is notorious for having some 8 ohm rated speakers that are difficult loads for 6 ohm rated AVRs.
post #6 of 6
Thanks for the replies =) will be picking up the system tomorrow
  Back to Forum: Speakers
