I need help hooking up my HTPC, BenQ W710ST 720P 3D ready Projector, Vizio E420VL 1080P 120 Hz TV, and Denon 2113CI AVR with 3D pass through. At the moment I am swapping HDMI cables behind the AVR (HDMI out) when I want to switch displays. Other then those cables I just have the HTPC sending Video & Audio to the AVR using the Video Cards HDMI out. I do have the cable companies coaxial cable split to TV and HTPC Tuner card.
I want to be able to use the 3D features on the projector. I am not sure how to properly set this up since the projector & TV have different resolution. I don't really have to have sound going to TV (keep it muted most of time) but it wouldn't hurt if it is easily done. I do need need sound from TV - AVR. I do not need sound coming from the projector. It would be nice to be able to possibly bypass the Video portion of the AVR just so I can switch the AVR to FM without disrupting the video but this isn't a absolute must have. My AVR has a video chip in it but I don't know if it would really help in my situation to use it. My HTPC video should be able to handle everything.
HTPC - Radeon HD6450 3D capable with DVI-D, D-SUB, & HDMI 1.3a. Also have on board video with HDMI, DVI, & VGA. Not sure if both Video cards can be used at the same time. The sound on the computer has a optical out, sound also passes through HDMI on video.
TV - http://reviews.cnet.com/flat-panel-tvs/vizio-e420vl/4507-6482_7-34112560.html
2 x HDMI (19 pin HDMI Type A) - Rear,
2 x Component video input (RCA phono x 3) - Rear,
3 x Audio line-in (RCA phono x 2) - Rear,
1 x Composite video input (RCA phono),
1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear,
1 x Digital audio output (optical) (TOSLINK) - Rear,
1 x Audio line-out (RCA phono x 2) - Rear,
1 x Audio line-in (Mini-phone stereo 3.5 mm) - Rear,
1 x HDMI (19 pin HDMI Type A) - Side,
1 x USB (4 pin USB Type A) - Side
Projector - http://www.benq.us/product/projector/w710st/specifications
Computer in (D-sub 15pin) x1
Composite Video in (RCA) x1
S-Video in (Mini DIN 4pin) x1
Component Video in x 1 (RCA x 3)
Audio in (Mini Jack) x 1
Audio L/R in (RCA) x2
Audio out (Mini Jack) x1
Speaker 10Wx1
HDMI V1.3 x2
USB (Type Mini B) x 1 (USB Download & Page up/down)
RS232 (DB-9pin) x1
AVR - http://usa.denon.com/us/product/pages/productdetail.aspx?catid=avreceivers(denonna)&pid=avr2113ci(denonna)
HDMI Inputs - 6 (3D/1080p/4K Ultra HD)
HDMI Outputs - 1
Audio Return Channel (ARC)
Digital Inputs: Optical 1
Digital Inputs: Coaxial 1
Analog Audio Inputs 5
Composite Video Inputs 3
Composite Video Outputs 1
Component Video Inputs 1
Any help would be most appreciated. Is it as easy as splitting the AVR's HDMI out to both displays?
Ken
Speaker 10Wx1
HDMI V1.3 x2
RS232 (DB-9pin) x1
HDMI Outputs - 1
Ken
