AVS › AVS Forum › Audio › DIY Speakers and Subs › Need Help for DIY Sub (Dayton Audio HO Reference 18")
Need Help for DIY Sub (Dayton Audio HO Reference 18") - Page 2
post #31 of 75
i zero out the inductance (le) because winisd does not do an accurate job of modelling that parameter.
post #32 of 75
Dual HO15s are arriving next week. I've locked the final design as follows;
Dual RSS390HO-4
12 cu ft net box volume
Dual 6"x27" round ports / Tuning Frequency @ 20Hz
Max input power 1000 watts
Here are the sims;
Cone excursion is a tad higher, but I think this driver can go uptill 14-15mm just like 460HO.
I need the final panel cuts. Can somebody pls help me do that? Actually, I can do it manually myself in excel but that does not factor in box internal resonances. I want a tower box having the ports on top side by side and drivers below them just like a 3-way tower speaker. Boxnotes is having me pull my hair. I gave it a shot but gave up. Also couple of questions;
  1. When we add driver displacement (Vd) into the net volume, do we use 2-way Xmax mutiplied by Sd?
  2. Do I have to add the physical volume of the driver basket as well that is inside the box in total volume or is only Vd required?
  3. Also, how to calculate the dimensions of internal braces?? Do i increase the box volume on gutt feeling by 1 cu ft and cover that extra volume in braces...sort of like reverse engineering?? Or is there any other precise way??
Edited by braveheart123 - 3/27/13 at 10:59am
post #33 of 75
Anyone?
post #34 of 75
Why such radio silence....can anyone help me out on this.??
post #35 of 75
others may have different views, but in my estimation no need to overcomplicate minor details, so:
1. no adjustment necessary
2. yes, but you can wing it by assuming the whole driver is about 0.2 cubic feet for a 15"
3. calculating the precise volume of the bracing is not necessary either. just try to get reasonably close.
post #36 of 75
I didnt understand the answer # 1. could u pls elaborate on that?
post #37 of 75
"1.When we add driver displacement (Vd) into the net volume, do we use 2-way Xmax mutiplied by Sd?"
there is no need to adjust the cabinet volume based on how much the driver will move back and forth.
when "driver displacement" is used in the context of adjusting the volume of the enclosure, it is the volume of the magnet, basket, and so forth...not how much displacement in terms of sd and xmax.
i can see how that could be confusing as the same terminology is used to mean two different things.
post #38 of 75
I get it now. Thanx for clarification. I will crack on with the build as soon as I get the drivers.
post #39 of 75
Took the delivery of dual Dayton RSS390HO drivers today, flown in all the way from US. I will be lining the walls with an inch and half eggcrate foam. Do I need to account for the extra volume occupied by it or not??
Any help is appreciated.
post #40 of 75
you do not
post #41 of 75
Even with ported design?? Mine is a ported one.
post #42 of 75
eggcrate foam won't do anything in a subwoofer anyway.
post #43 of 75
Then how to avoid standing waves and dampen the sound inside the cab? The dimensions are not exact multiples of eachother.
post #44 of 75
u don't need to worry about it really . heavily stuffed lightly stuffed lined with foam are all so close to the same when measured its within the realm of being errors in testing. i wouldn't recommend lining a sub with any foam though it just makes the box smaller less air and u lose low end. i would stuff lightly with polyfill as most do.
post #45 of 75
It will damp internal reflections of above bandwidth harmonics.
Then how to avoid standing waves... inside the cab?
Do you have panel to panel distances of at least 1/4 wavelength within the speaker passband? If not then there are no standing waves of major consequence, though some in the midbass above the passband could be excited by the harmonic content in the signal if the low pass filter lacks adequate slope to filter them out. Even if there are no harmonics in the signal the driver will create them, but a couple of inches of foam, polyester battting or type 700 fiberglass will take care of that.
heavily stuffed lightly stuffed lined with foam are all so close to the same when measured its within the realm of being errors in testing... foam though it just makes the box smaller less air and u lose low end. .
I'm afraid that none of that is true.
post #46 of 75
Thanx BFM for such an explicit response, but a little more clarification required. I cross my sub at 80Hz, so while calculating a quarter of wavelength of sub passband, which frequency is taken into account?? I mean sub is playing from 80Hz down to 20Hz with a 2nd order HPF on 20Hz. Which frequency should I choose to calculate 1/4 wavelength??
Sorry, but I didn't understand it. Thanx
post #47 of 75
The highest one. 1/4 wavelength at 80Hz is 3.5 feet, at 20Hz 14 feet. You can see why with modern subs standing waves tend to be moot. They will arise in bookshelves, but in the midrange frequencies where they do they're easily damped. They can be an issue in full range towers, so with those care must be taken to use adequate damping at the top and bottom if they're not sealed stuffed enclosures.
post #48 of 75
"It will damp internal reflections of above bandwidth harmonics."
there is no practical benefit to that.
post #49 of 75
If you don't think so then by all means leave your subs empty. I've measured the practical benefits, so I'll continue to recommend it.
post #50 of 75
What should be the panel to panel distance? Should it be more than or less than or equal to 1/4 wavelength of speaker passband (80Hz in my case)?? My box dimensions are 50" H x 24" W x 18.5" D. The height is 50" internal, which is more than 3.5 feet. Is it matter of concern for me?
post #51 of 75
It is. I'd use four inches of foam or glass on the panels at either end of that span.
post #52 of 75
It's a dual driver box housing Dayton RSS390 HO drivers. I can't change the width and depth coz of placement. I'm pretty much stuck with only one possible location in the listening area. So, height is the only this I can play with. Could you pls guide me on the wavelength issue?? Should the panel to panel distance be more, less, or equal to at least 1/4 wavelength of the passband??
post #53 of 75
Originally Posted by Bill Fitzmaurice View Post
The highest one. 1/4 wavelength at ....
Bill,
To my understanding, standing waves in a closed box are integer 1/2 wavelength multiples... making 80Hz a 7' half wavelength that won't fit in 50" rendering braveheart's concerns moot.
http://en.wikipedia.org/wiki/File:OpenCylinderResonance.svg.
1/4 wave odd-integer multiples apply with one end open and the other closed - a Coke bottle. I don't see a port changing this...
http://en.wikipedia.org/wiki/File:ClosedCylinderResonance.svg
I know of no downside to (sanely) lining the interior of a ported sub, and Bill's suggestion for end damping fits this scenario. The fact is that subs produce far higher levels of non-linear distortion than we'd ever accept in the vocal range, for example. Ricci's data doesn't include a vented box (used a passive radiator design instead) so his vented data is optimistic... but you can see why Bill can measure a benefit!
But I don't see a standing wave scenario here.
Have fun,
Frank
post #54 of 75
Originally Posted by fbov View Post
Bill,
But it is 1/2 wavelength at 160Hz, and there's plenty of second harmonic content in subwoofer output. True you don't get the 1/4 wavelength resonance of an open ended pipe, but still once you get to where there are 1/4 wavelength pathways panel to panel you're best off to be sure there's sufficient damping to take care of what may arise, because even if it's a third harmonic that can be pretty significant.
post #55 of 75
Hi BFM, the lining didn't work in my other slot ported DIY sub (Alpine SWR-1223D). It badly strangulated the response. I removed the lining and it was a day night difference. Um sure u must be right about lining the sub box walls but it didn't work for me. May be coz that box is 5 cu ft gross that is internally dimensioned at 15" W x 24 " D x 24" H. And no wall to wall distance is more than the quarter of passband.
Any thoughts?
post #56 of 75
Any thoughts?
You can over-damp a cab, especially with thick foam, and with a ported cab you have to be careful not to have any damping near the port entrance, as that will throw the tuning off. I've seen guys use memory foam and that will kill the midbass big time, it's just too dense.
OTOH it could have been that the box was just wayyy too big for that driver. I didn't model it myself, but Alpine recommends 1.5 cu ft.
Edited by Bill Fitzmaurice - 4/16/13 at 4:34pm
post #57 of 75
"If you don't think so then by all means leave your subs empty. I've measured the practical benefits, so I'll continue to recommend it."
of egg crate foam lining in a subwoofer?
post #58 of 75
What to do about it now? Would I have to revisit the box size?? The internal dimensions are 24 W x 18.5 D x 50 H. Tuning frequency is 20Hz with dual 6" x 34" round ports.
post #59 of 75
But it is 1/2 wavelength at 160Hz, and there's plenty of second harmonic content in subwoofer output. ....
You're calculating for the 2nd harmonic directly as the onset of HD-driven standing waves. As you said: "The highest one. 1/4 wavelength at 80Hz is 3.5 feet..."
I was thinking along siimilar lines, but discounted 2nd in favor of 3rd, thinking it's easier to fit a higher harmonic. The problem I had, looking at Ricci's distortion data, was the low level of 3rd harmonic... below 1% by 40Hz in both sealed and tuned alignments and 120Hz still too low. There is no shortage of 2nd harmonic... both alignments are ~5% well past a normal sub LP cut-off.
(Note this is all at a 113dB output level from a TC Sounds LMSR-12, save for the horn, which has less distortion at 6dB higher SPL.)
5% is -30dB, and it's quite possible for a standing wave resonance to build that high... talk about a localizable sub!
Thanks for the inisight, Bill.
HAve fun,
Frank
post #60 of 75
Forget it. I've changed my plan of housing two subs in one enclosure. Um building 2 seperate enclosures 5.5 cu ft net each with a single 6" x 27" port tuned to 20Hz feeding 850 watts with the buffer of jacking the power upto 1200 watts after breaking them in and still keeping the port velocity in limits, as well as, the cone excursion. The first port resonance is 3 octaves above the passband. The end result will be the same i.e. greater than 115dB @ 20Hz.
I guess keeping it simple is better.
Thanx folks for your input.
