AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Epson 9500UB Worth the Price?
post #1 of 11
Hey folks, my 3 year old Epson 6500UB is showing convergence and banding issues so I've started the search for a replacement unit.(No warranty)
I received an additional bulb when I purchased the 6500 and it's still in the box and I'd like to be able to use it on a replacement.
So I found a fellow selling his 9500UB with this description...
"Like new the amazing Epson 9500ub projector. 200000:1 contrast ratio. If you're looking for this projector then you already know how good it is. Comes with brand new extra bulb from Epson($299 Value) The current bulb has 680 hours on it.(4000 hour bulb) Comes with original box, packaging and remote control. Upgrading to a 3D projector." Also, the projector was ISF calibrated. The seller reports the unit as 2 years old without warranty.
The seller is asking $1,800 for the unit.
Seems to me that's high but I really don't know if the 9500 is that much better than the 6500. Did/does the 9500 have the same issues with the light engine as the 6500?
Is this good value or would a new 2D/3D Epson or the Panasonic 8000 be better choices?
Thanks for all your opinions.
post #2 of 11
That is too much $$ for an outdated model, you can easily find an Epson 5010 for that price and get the 3D as well.
post #3 of 11
Or the Benq 1070 for about $1k if you can't swing the price for the 5010. Either would be a better choice as your buying new vs a used unit, and getting 3D as zombie said.
post #4 of 11
I have a 9500 and it's great PJ! It did get replaced with a new one within the first year because of very slight pink and green. This was only visible on a pure white sceen..the replacement is perfect in all regards.
Mine has been ISFed and has 700 hrs. on a new blub, I still have a new spare. I would only go for a 6010/20 if I had the money.
If you're really into 3-D, I guess the 5010/20 would be the way to go, but don't they have a white housing? It sure wouldn't look good in my black HT.
Mine cost $3400 back in 2010 and now it's not made anymore. Since you won't be able to see in action, I'd try to get him down in price. $1000 to $1500 would probably be a better price. If it has that pink/green, I'd ask to give it back for a refund.
Tough decisions to make and good luck with whatever you do.
Edited by inspector - 3/12/13 at 3:39pm
post #5 of 11
That seems too much. I just bought and received a refurbished 9500ub from Epson Store for $299 few days ago. I opened the box and powered up to see how it look. The unit is awesome so far but time will tell, but anyway I still have 3 years warranty if some problem arises. When I have time I'll playing around with calibration. Besides I have an Acer H5360 720P projector that I like.
post #6 of 11
did u say you bought a refurbished 9500ub for $299?
WOW
post #7 of 11
Did you mean you bought a lamp for the 9500ub from the epson store for $299? The current price on the out of stock refurbished 9500ub is $1899 and their cheaper 8350 refurbished projector sells for $899 on their site.
Mike
post #8 of 11
Yes. It was $299 then. Attached's my invoice.
. DSC_0516.JPG 464k .JPG file
post #9 of 11
Goodness...what an awesome deal !
post #10 of 11
Wow!! Awesome deal indeed!! I thought there was no way you could've gotten it for that price. I stand corrected. Did I say Wow? smile.gif
Mike
post #11 of 11
Probably an error in their system, someone entered something wrong and then fixed the price later, but they honored it.
