AVS › AVS Forum › Audio › Audio theory, Setup and Chat › IN/THRU?
IN/THRU?
post #1 of 3
I posted this in the Sub forum, but no one there's been able to help me.
At the club I spin at, we have to move a sub from the back room to get the main room to sound proper (even though there are already 2 in that room). All of these subs are JBL SRX728S. The manual here (http://www.jblpro.com/BackOffice/ProductAttachments/SRX700UserGuide.pdf) shows the back. There are two speakon connections and both are labeled "IN/THRU" what does the Thru mean? Can I daisy chain theses subs together?
Cheers for any help
post #2 of 3
I would say so. in/thru must be the same as in/out as on other subs.
post #3 of 3
The markings you mention are common on speakers for professional audio and mean exactly what you have deduced. SRX series JBLs are intended for professional audio - more specifically live sound. That doesn't mean that they don't belong in a home audio system if they fit.
http://www.jblpro.com/catalog/general/productfamily.aspx?fid=10&mid=3
"For over a decade, JBL SR and SRX series speakers have represented the best performance, highest
quality and most advanced driver technology available to portable PA users. The SRX700 Series
continues that tradition and moves the bar even higher. The advanced technology of SRX700 Series
speakers delivers the power and performance that you would expect from the highest quality, professional
rig. At the same time, JBL innovation and design have reduced system weight so load in and out are a
breeze. All this performance is housed in rugged birch enclosures for years of superb performance"
