Hi all, when looking at the watts of a receiver, brands post different watts depending on the test they use. for example:
Power Output Per Channel(20Hz-20kHz, 0.08%THD@8ohm) 105 Watts
Power Output Per Channel(1kHz, 0.7%THD@6ohm) 135 Watts
Max Power Output Per Channel 215 Watts
when finding speakers to match with a receiver, which of these watts specs should I be looking at? should I be buying speakers that are 105, 135 or 215 watts?
thanks
thanks
