AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Technosonic LCD3251 display issues
post #1 of 2
Philips PLCD 190 PT3 Power board
AM0005-BAC Control board
6870C-0060F T-Con board
663-2L 0211A Inverter board (right)
663-2L 0212A Inverter board (left)
If photos are required I can post them up.
At first switch on the front panel red led light comes on solid and then flashes 2 times then 5 times.
The TV comes on but the picture is distorted as per attached picture, sound works fine.
This is the same on Scart 1, Scart 2 and Antenna In but HDMI and PC Inputs are perfectly fine.
I can access the OSD Menu from a universal remote or by a combination of the front panel buttons and all the functions work.
The OSD Menu appears perfectly fine.
The usual visual inspections have been made but no signs of anything obviously faulty, i.e bulging caps, burnt areas, dry joints.
Uploaded with ImageShack.us
Any help would be greatly appreciated. Thank-you.
post #2 of 2
So does anyone know how to 'test'/check a TW9906 Comb filter video decoder and associated clock generator?
