AVS › AVS Forum › Video Components › Home Theater Computers › Is it possible to use MediaBrowser to see my TV recordings?
post #1 of 6
I have TWC (flagged Copy Once) so I use WMC. Cable card tuner is HDHomerun Prime.
I've seen how good looking Media Browser can be. I was wondering if it was possible to use that front end to see my recordings, but then still be able to have the files play correctly considering they are flagged copy once.
If not, I would just be using Media Browser for Games.
post #2 of 6
yea you can do that. media browser wont be playing them, windows media center will be.
post #3 of 6
Thank you! I'll see if I can make it happen.
I bought the Assassin guides, so here's to hoping that will show me the way.
post #4 of 6
If you use MPC-HC as your player, CopyOnce won't play back. I need to mess with the MediaBrowserConfigurator but I think it can be set to use the WMC player for *.wtv files and MPC-HC for every thing else.
post #5 of 6
I actually won't have anything else to play back except for .wtv files. I dont use the computer for movies or music. Just games and tv.
post #6 of 6
The default for Media Browser is the WMC player so it should work fine.
