I had to replace a blown woofer in my Triad Platinum sub. I have already received my replacement driver and took out my old blown one too. However, when I was putting in the new driver, some of the screws did not tighten, they went in, but just would continue to spin if I tried to tighten them. Assuming the holes are stripped or something.
So my question is, do I make ALL new holes for the screws or do I add some adhesive to make them tight, or do nothing?
