AVS › AVS Forum › Video Components › Home Theater Computers › Need advice
Need advice
post #1 of 9
Hello Forum.I am not new to XBMC as I have been using a ATV2 for the last year with mixed results.It has been good but the ocassional buffering has me looking for another option.I have found a nMedia PC htpc-6000b for sale.It is running windows XP with 2G of ram.the board has a dual core processor and the seller tells me that it also has dual wireless cards installed .This is all I know about it at this time.What questions should I ask the buyer and am I right in assuming that this will be far better than the ATV?Any help and suggestions would be appreciated
post #2 of 9
Could be anything inside.
We need to know the specific parts and price to offer any advice.
post #3 of 9
XP and 2GB of RAM - something tells me the dual core processor is obsolete. Still, for the right price this could be turned into NAS or something.
post #4 of 9
OK I just got home from checking it out.
It has
an IBM thinkCentre E50 41D1793 socket LGA 775 DDR2mother board L1915F
160 GB Seagate harddrive
2 matched PC2 8500 1G sticks
Dual wireless card
I am to understand that this board is upgradeable and that I could use an adapter for the HDMI output for the time being until I could find a good Sound and Video card.(although I was told I may likely be happy with the resolution of the motherboard)
Found this at a pawn shop and they are asking $249.00 for it.Does this sound unreasonable for this system?Forgot to mention they are including a wirless keyboard and mouse and a computer speaker set.
post #5 of 9
Here are some pics I took as well
post #6 of 9
Its not worth half that. Just look what you can get on Newegg for a budget machine (before even considering refurbs):
- AMD Dual Core E-350 1.6GHz
- 4GB DDR3 1333
- 320GB
- AMD Radeon HD 6310 GFX
- Gigabit ethernet
- KB + mouse
- Windows 7 Starter
- 1yr Warranty
$239 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16883258004
post #7 of 9
Awfully outdated, manufactured in 2004. Stay away.
post #8 of 9
Thanks for the input.I figured the componants were older but didnt know if I could get by with them for a while until I could slowly build a better one.I still may try to make a deal with them just for the case.I know they are about 140 shipped new.What would be a fair price just to aquire the case.I am sure I could resell at least the RAM for a few bucks as well
post #9 of 9
nMEDIAPC HTPC 6000B (brand new) is ~$90 shipped. It's pretty big (7 full-height expansion slots, 6 HDD bays).
