I am currently using 3 Ascend Acoustics Sierra-1's in my smaller room, (not my main system), and I am wanting to build some type of woofer setup to fill in the gaps that the Sierra-1 bookshelf speakers can not possibly fill. I would like to have the woofer in my Sierra-1's only cover the mid-range frequencys and then have some sort of bass woofer to cover from where the mid-range driver in the Sierra-1 falls off.
I have no idea how to properly impliment my ideas, and would like to get some opinions on this matter.
The basic idea would be to have the mid-range driver in the Sierra-1 cover from its bottom range, where it would start, to its upper range, where it crosses over to the tweeter. (note that I am having Dave install some RAAL tweeters in my Sierra-1 bookshelf speakers, so I am not sure if that would complicate things?)
Does anyone know what the optimal frequency range of the 5.25" driver in the Sierra-1 is supposed to cover? If I wanted to build a woofer cabinet to cover the lower-ish bass and the mid-bass up to the 5.25" mid, what would be a good woofer and enclosure to use for this purpose? I have considered the JBL2226, but am open to all suggestions. Thanks guys!
