AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › non-FiOS use of ECB2200 coax network adapter
post #1 of 5
can I install Actiontec coax network adapter ECB2200V on my non-FiOS cable to TV ?
post #2 of 5
It will work with any MoCA compliant router/modem. The ECB2200V isn't a device that will work on it's own though. If you don't have a router/modem with MoCA enabled you would need a ECB2500 or similar device to connect to the router/modem and bridge the coax network to the ethernet network.
The ECB2500 also comes in a two pack to connect one to the router/modem and one to a switch or device at the other end.
http://www.amazon.com/Actiontec-Ethernet-Adapter-Service-ECB2500C/dp/B008C1JC4O/ref=pd_sim_e_3
post #3 of 5
will the netgear moca device work with this?
post #4 of 5
Work with FiOS? Yes it will.
post #5 of 5
If you are asking if the Netgear MoCA bridge will work in your setup, it will if the MoCA network is setup correctly.
