Originally Posted by
clumb31
profhat
Let's try this: unplug your Crapcast box from the Emerson, and record for a minute to your HDD, then try to dub that tittle to DVD.
If you can make the dub, the issue is due to the friendly Greedywood CP flag .
Perhaps I have confused you and used the wrong terminology.The Emerson IS what I have been calling the HDD. As I understand things , it has a hard drive that has been recording the content. Should I have given it a different name?
The content recorded on the Emerson hard drive was such things as PBS specials. It came from the cable box, via coax- this is the only way I can get TV
In the case of a unit with built in hard drive, brand name and HDD are synonymous in his reply. We need to drill down whether your Emerson is being victimized by errant copy protection signals from the cable box, or whether the symptoms are due to the unit malfunctioning.
So, we need you to connect an old vcr or another dvd player to the Emerson and record something (an old, non copy protected, recording made before these issues cropped up) to the HDD (hard disc drive) and try dubbing it to a blank dvd, If you aree able to dub successfully, that tells us that your Emerson is still in good working order, and you are indeed, getting hit wil CP from Comcrap.
