Hi Guys,
First of all I'm a total noob at building frames/screen material, however, I've been reading a lot of posts on the forum to try and learn.
I am buying the new optoma hd25/hd131x which are the same but in different color, and I am wandering what is the best solution for the screen material.
I stumbled upon this great DIY screen : http://www.avsforum.com/t/1303114/amazing-grace-theater-build
he used Wilsonart Designer White Laminate as the actual screen, but I saw other options as well:
I saw a couple of da-lite fabrics that were recommended: high power with 2.4 gain, costs at http://www.avoutlet.com 15 dollars per square foot, Cinema Vision with 1.3 gain that costs 6.2 per square foot
I also saw an option to buy a spray can and spray a special paint on the wall.
Can someone PLEASE help me sort this out?
Thanks for any help.
to be found in Israel Sintra is a US-Branding of a material described as being: "Rigid Expanded PVC Foam Sheeting (6mm)
