AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Wall mount question for Epspn 5010
post #1 of 3
Anybody use this wall mount for there Epson 5010 projector? I am getting ready to purchase this projector, and want to wall mount it, but don't know if this mount will work? The web address is:
http://www.mountdirect.com/NPL_Projector_Wall_Mount_p/npl_w.htm
Or if anyone knows of a good wall mount that works i would appreciate it.
post #2 of 3
I know you didn't ask this, but another option is $25 at Lowes or Home Depot. You could get a 2x2 piece of plywood, a couple of steel brackets, and some lag bolts to make a shelf. They'll cut the plywood to size for free. If you're like me, you probably have some paint sitting around to spruce it up. If not, both stores sell "sample" sizes of paint for $3 that would cover this project. As long as you screw into 2 studs, you'll have more than enough support.
It's such a small project that it might be fun for you, you could save a few bucks, and have your mount today.
post #3 of 3
I was thinking about this one, not a true projector mount but looks good and is not expensive:
http://www.amazon.com/OmniMount-ECSB-Component-Shelf-Accessories/dp/B000EGI7V4/ref=cm_cr_pr_product_top
