AVS › AVS Forum › Video Components › Home Theater Computers › Do I need the LAV codecs?
post #1 of 5
I'm following the assassin htpc guide and one of the first things e does is have you install the LAV splitter for codecs
If I'm just watching recorded TV on my htpc do I still want to do this?
post #2 of 5
Not needed if that's all you are doing.
Venture away from that and the answer is yes.
post #3 of 5
I use WMC for Recorded TV and XBMC for all other video. I don't install any codec packs.
post #4 of 5
Correct. But if you want to use the wmc player and mkv you have to add something. No way around it.
post #5 of 5
For sure.
