AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › PROBLEM - PDP-5080HD
post #1 of 2
I have a PDP-5080HD /KUCXC I bought in 2007 that's been great, but just recently I noticed the TV guide is not populating any longer and afew days after all the channels are fuzzy on input A, and when connected to input B there clear like it use to be but will not populate the guide. Only input A is meant for the guide.
I did the reset,
1. Go to TV Guide
2. Go up to the navigation bar.
3. Arrow to the right, until you highlight the Setup tab.
4. Arrow down once to highlight "Change System Setting". Do not hit enter.
5. Enter code 65 32 74 14 7 then wait for the TV to turn off.
TV will turn off and blink 12 times, so does this mean the digital cable tuner is finished?
Would this be the board I need to replace? -> http://www.ebay.ca/itm/PIONEER-PDP-5080HD-X-Main-Board-AWV2447-ANP2183-A-ANP2183-B-ANP2205-A-30502-/130832694111?pt=US_TV_Boards_Parts_Components&hash=item1e763c7b5f
what would be the part number? should I call pioneer?
My conclusion comes from looking around and pulling up this info; -> http://www.justanswer.com/tv-repair/599fq-purchased-pioneer-plasma-pdp-5080hd-2008-recently.html
Gear mentioned in this thread:
post #2 of 2
Originally Posted by Pir8pete View Post
I have a PDP-5080HD /KUCXC but just recently I noticed the TV guide is not populating any longer ...
I do not know anything about Pioneers, but could it be related to the discontinuance of TVGOS?
