I recently installed this system,have it hooked up to a Denon 1913. The issue is that when I turn the system on, the sub is supposed to recognize the signal and also turn on automatically, however, it is not doing that. The status light goes from a steady red when the system is off, to a flashing red when I turn the system on (it's supposed to turn green). I've found if I unplug the sub for a little while and then plug it back in, it works as it should. Suggestions?
PS: I should note, that I have the sub hooked up using def tech's "method 1", where the fronts run through the sub instead of straight from the receiver. Could this be the issue?
