AVS › AVS Forum › HDTV › HDTV Technical › Test patterns on Comcast cable?
post #1 of 5
Is there any way to see test patterns such as pluge patterns or color bars on Comcast cable? I couldn't find anything in the forums, and the kid I spoke with at Comcast was clueless? Thanks. Jack
post #2 of 5
I don't know why they would broadcast those. And if they did, they would be compressed as hell.
post #3 of 5
i am in walnut creek ca. with comcast. there is a channel with color bars on the highist channel.
milt
post #4 of 5
Since there is a lot of repetitive data in a test pattern I should think they would compress and restore fairly well. Consider color bars for example. The entire pattern is comprised of around a dozen pieces. Why not compress it?
post #5 of 5
What are you trying to do?
  Back to Forum: HDTV Technical
