OK, i'm sure this subject has been dealt with, but after trying a lot of setups, i still have trouble with this situation.. My previous setup was a pionner Elite VSX 82 with Axiom speakers 5.1 Epic 500 setup. My Blu ray was my PS3 so maybe there is part of the equation but with my DVD player of another make same problem: When i listen to a movie soundtrack , the voices are WAY less loud then all other action and effects noise... This is so bad that i have to play with the volume on my remote continuasly or everthing is exploding in action and wispering in voices. Don't worry, i played around with the dynamic range compression on the PS3 and or dvd player, as well as on the Pioneer amp... tried direct, and all formats of dolby and digital on my amp. I also tried to increase db on the center channel on the amp as well.... The problem stays there. The problem seems a lot worse when i Watch translated french versions., even in 5.1 digital, and also seems worse if sound level is low. So when i play loud and in original English soundtrack, its tolerable.. but in normal day to day watching, its always a problem...
The good news is i am moving and am going to re do a new system.. so now is the time to plan ahead...
what do i need to do to solve this..
thanks...
i'll do what i have to...
thanks...
