Originally Posted by
nove18it
i am new on this forum. i have a compatibility issue with 50p edited video playing on ps3 (i use powerdirector 11).
can you/someone please send me pd9fix file/s ? i cannot find anywhere! my mail address is crisroller@tin.it or tell me
where i can download it from? thank you very much
Cris
I have authored all my Panasonic HDC-SD700 1080/50P footage with full Menu & Chapters
to non compliant Blu-ray BD Media and AVCHD DVD R/RW media with the free MultiAVCHD & ImgBurn applications.
The BD and AVCHD Media plays without any problems on my Sony PS3 and Samsung BD-C6900.
MultiAVCHD(free tool) will author non compliant 1080 50/60P Blu-ray or AVCHD discs.
Output can be burned with ImgBurn(free tool) to DVD R/RW or BD-R/RE discs for playback in AVCHD-ready players.
Before you use MultiAVCHD please note the following below:
The ouput video from Power Director 11 dose not contain standard header.
Therefore MultiAVCHD will abort. To fix this you can download a free trial version of VideoReDo H.264.
With VideoReDo H.264 all you need to do is input your PD11 *.m2ts output & write the output also as *.m2ts, which will generate the correct headers.
Video & Audio is out of sync if you use pd9fix .
