AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Ultra-thin bezel on 55" to 60" up to $1000 - which models should I consider?
post #1 of 5
We just bought a new house and In the future I will be setting up a project-based home theater in my basement. Right now though I am looking for a 55" to 60" HDTV to mount on the wall above the fireplace. The room is decorated in very light colors; yellow, white and cream, so a thick black bezel around the TV will detract from the rest of the room. Which is why my main focus is on minimizing the bezel and/or blending the TV into the rest of the room.
Because this won't be our main movie & TV watching display I'm less concerned about picture quality and features and more about the physical look. High quality built-in speakers would also be a benefit as there will not be a full surround sound set-up in this room.
I've looked at the Toshiba 55L6200U and it looks great. I'm just wondering what other TV's I should consider. If anyone has any recommendations that would be great.
post #2 of 5
The bezel on the Vizio E60i1-a3 is about as thin as I've seen.
Very happy with mine!
edit. Not as thin as that Toshiba I notice!
post #3 of 5
Sharp 60 650U. It is available on Amazon for $1199.
The Vizio is $1000, only 200 cheaper than the Sharp. Since the price difference is so small I would get the Sharp.
If you wait few weeks there might even be a price cut.
post #4 of 5
The L6200 is a great option given what you're looking for. Solid performance, nice aesthics, backed by a top-tier brand.
I personally think you can find more viable options than the Vizio model in question here.
I'd also give a strong look at the EH6000 series from Samsung, solid performance for the price, and has a very low-profile bezel.
post #5 of 5
I ended up getting the Toshiba 55L6200U and love it. The thin bezel really makes a difference aesthetics-wise. I've got it mounted with a super low-profile mount, it nearly looks like a window.
