Originally Posted by ConnecTEDDD
Hey SS, the results that counts to check/compare any LUT are the Grayscale/Saturation etc. Charts of the Final LUT Loaded @ eeColor.
Other charts of Virtual Cube Generator etc are useless at this point. Use eeColor connected at Unity LUT while performing AutoCal.
We need the final image to be as accurate as possible...
Hello Ted.
Check also Grayscale/Color Ramps / Clipping Patterns for any problem with the LUT loaded.
Hello Ted.
Yes the last LUT I ran with 21 point GS is using eecolor, however the two problems I am seeing is when using the Mini as a pattern generator and its 21 step grayscale pattern, there are some small hint's of color at a few of the steps. Also using S&M disc it seems to show color clipping, of-course this could be caused by my Oppo 95, however the color clipping never showed up when I used the Mini as the processor for a 125 LUT/21 GS.
ss
