AVS › AVS Forum › Video Components › Video Processors › Darbee Full Pop 100% Reset
post #1 of 2
After using my Darbee for 4 months without an issue, the unit just reset itself without doing anything. The evening before it was the way I had it set and than the following evening is was set back to its factory default state. Why would the unit reset itself in such a way? I hope this is not an indication of a problem starting to occur with the unit.
post #2 of 2
There's a whole thread about the Darbee, and your situation is discussed.
http://www.avsforum.com/t/1399154/darbee-vision-darblet
  Back to Forum: Video Processors
